I have twin 200hp HPDI motors and the port motor will not rev beyond about 2400 rpm and is rough running. Replaced all filters including the small basket filters in the injectors and pump. Mechanic with YDS checked out and first replaced the TPI which made no difference then says the high pressure pump is not putting out correct pressure at higher rpms. This is an expensive part new so I sourced a used one claimed to be taken off a good running motor. Mechanic installs this pump and says that it is no good also. Losing confidence in this mechanic. What are the odds of two pumps being bad? Is it possible to rebuild these pumps like diesel injector pumps? I should mention that I'm in a small town in Baja and this mechanic is pretty much the only **** in town. Any help???
I suppose I should mention a few of the things I have done to try to diagnose. I think I have ruled out bad fuel as the tank has fresh fuel and the Stb motor runs perfectly. I also tired swapping the ECUs and Injector Drivers from the good engine to the bad and made no difference. The plugs on the bad engine are very black and sooty looking, not wet at all.
