Command Link gateway to display 2019 Yamaha engine data on Raymarine Axiom MFD stopped working - troubleshooting help
1. check all fuses - all worked - 1 on RED power cable to CL hub from remote control.
2. I removed the back cover of CL multi-hub and found 11.2 volts on the 2 long stainless steel plates inside the CL multi-hub (Unsure if 11.2 is enough to power all the plugs on CM multi-hub
