Hey rowdy roddybolt. Easy easy. I understand that the ecu doesn't monitor fuel pressure. Think you already told me. Remember that i am just a backyard mechanic, with 20 years of experience with yamaha snowmobiles, snowblowers, motorcycles, waverunners, etc, and i work 9-5 as a professional mechanical engineer. Dont refer to me as dense. I am open to learning this stuff but seems like you might have closed up all your books. Trying to give as much info as i can so that i can get to a solution faster that is all.
That said, just confirmed that all injectors and fuel pump is new. I have changed to a portable tank as well. When I say that this engine goes into rpm reduction, maybe I am not right. But I can guarantee that the ecu or Cdi or something is systematically reducing rpms after I try to accellerate. Anyway, for those who don't agree, how about we agree to disagree.
I just had the boat in the water for a trial and nothing had changed. I did check the #2 and #5 cylinders to see if they were firing at idle and they weren't, which from what I understand is nornal. Anyway, I did check the voltage on the sensor and was getting a low reading while cranking and nothing when running. I tried unplugging the sensor and there was no difference in the engine when idling. I tried it in gear and to wot wit it unplugged, and the engine got the boat up on plane and seemed to run fine. I kept it running on and off plane for about 20 minutes and ran perfect. Anyone care to comment?
I also found out that this engine was just rebuilt by the dealer. How exactly does the cps tell the position of the crank when all the teeth are the same on the ring gear? Is there anything on the inside of the ring gear that causes the signal to become irregular tell where the crank is in its rotation? Any chance the ring gear is not installed in its proper location and is telling the engine false info on the crank position? I don't have that part of the service manual to confirm what the correct position is.
All comments welcome guys.
