VZ 200 HDPI 2.6L running issue
  • VZ 200 HDPI 2.6L running issue
    Looking for a little guidance on this please. Engine came in with running issue( not run since before hurricane Michael) so vst psi 44 psi, high pressure pump 690-725 psi, injectors cleaned and tested, injector driver voltage tested all 88-90 to injector loaded. all fuel filters changed running on shop tank. did sync and link according to service manual but to get it to the proper rpm the TPS goes to almost to .70 and the throttle valve opening is about 4.5. Cleaned O2 sensor and checked voltage all good. Did notice that when I unplugged an injector the rpm went up not what I was expecting any thoughts or voodoo magic would be great. Thanks in advance.
    Gunz
