4hp cam timming marks
  • 4hp cam timming marks
    Can any one help me with where the cam timming marks are on a 2006 4hp 4 stroke yamaha outboard.
    Do you know anything about alternators?
      A complete model # and serial may get you some help
        Any alternator will work on any truck. Black, blue, red, brown, it does not matter.
        Any questions, see Rodbolt.
          10-4 will do
            mistake on answer
            Looks like livinglinelife thinks I am asking about an alternator. I am putting a 2006 4 hp 4 stroke model f4MLH outboard back togather has been taken apart and I am installing a new cylinder, when installing the crankshaft I need to know where the marks are on the cam are, I see the mark on the gear but I don't see any marks on the cam except a parting line but that is on both sides.
              The camshaft driven gear should have a dot on it. The crankshaft drive gear should have a dot on it. The camshaft is properly timed to the crankshaft when the dots are opposite each other.
              You really need to have the applicable service manual.
                No, he wasn't.
                Its just that folks don't post a model # for their engines a good part of the time and its usually needed.
                Ie; I need an alternator for a truck... Model, year, etc???
                  Cam timing
                  Boscoe99 that is what I was looking for thank you very much.
