The symptom was erratic power with the RPMs going from normal to 0 on my digital at exactly the same time as the loss of power. Now the problem is constant. Already spent money on the rectifier. New fuel pumps and carbs rebuilt. Pulser coil?
1995 Yamaha 200 2-stroke loss of power and RPM reading
Rodbolt, I broke down and took it to a professional shop who couldn't fix my problem (3.5 months later). I am back where I was. How do I test the pulser coil? And just to be thorough, the 12V inputs into the CDI, not sure which wires.Last edited by neilftucker; 04-29-2015, 11:30 PM.
You took your motor to a shop....not a "professional" shop if they couldn't fix it in over 3 months, do you have a genuine manual for your motor to at least do some trouble shooting correctly? Listen to Rodbolts advice, and answer any questions asked, do not get tunnel visioned and keep chasing single possible parts, test them in methodical order, and test them properly.
Thanks, a big part of the reason he couldn't/wouldn't fix it is the engine is Frankenstein. Has a different foot, bracket and who knows what else, so I don't know the exact model number. But based on some parts I've replaced, I can pin it down to a '94 or '95 2-stroke 200 yamaha counter-rotation. So L200TXRS or L200TXRT. I guess I'll get one of those manuals.
I forgot to mention that an additional symptom is the loss of power is only on the low end, and is related to too much fuel, which leads to spark plug fouling...Last edited by neilftucker; 04-30-2015, 07:02 PM.
Okay, for anyone who is listening, I found out I have a 225 instead of a 200... so 225TLRT.
Anyways I got a service manual and tested the CDI for resistance and the only thing that didn't check out was the pulser coil W/G wire to all the others. Resistance was consistently too high; 190k to all other whites and 174k to B (spec was something like 170k and 68k).
My question is, would this match up with symptoms? Does this mean my CDI is bad? All because of one bad signal? Thanks for any responses.
symptoms: The symptom was erratic power with the RPMs going from normal to 0 on my digital at exactly the same time as the loss of power. Now the problem is constant. The loss of power is only on the low end, and is related to too much fuel, which leads to spark plug fouling...Last edited by neilftucker; 05-05-2015, 01:33 PM.
Is your engine a V90 or V76? Makes a big difference on a 225 in the year 1995Last edited by frankjohnson; 05-06-2015, 12:19 PM.
ÂÂ
