I have just installed this motor on a sailboat with remote controls. My engine panel has an indicator light space. Is there a way to change the oil pressure switch to a switch that turns the light out when the motor is running and oil pressure is normal instead of the stock switch that turns a light on when running and normal oil pressure. If not is there a way to have a light that goes out when the charging system is functioning properly. Having a light that burns all the time when the motor is running would be annoying.
Thanks for your help.
