I have an error code 37 "Intake passage air leak" which is stored in the diagnostics menu using YDS 1.33 software. The motor is a 2017 F70 Yamaha.
The motor has 70 hours and this error code occurred at 48 hours.
Motor is running fine and all live diagnostics are fine.
I presume the ECM determines an air leak using the air pressure intake sensor?
I have checked for leaks and all seems ok.
