Buzzer
  • Buzzer
    I have an 02 90hp Yam
    90TLRA
    6HI L 509357
    The alarm starts as soon as the key's turned on.
    I have unhooked the temp sensor so it doesn't get a signal from that.
    The motor is cool, hasn't been started.
    The oil tank is clean no crud. It is 2/3 full.
    The alarm shuts down if I move the float up to about half way.
    But if it goes all the way to the top the alarm sounds.
    I figure the alarm sender(level gauge assy.) is bad?????
    Any thing I should test or look for?
    The tach doesn't have any lights or any indicators just the buzzer.
    Thanks,Jerry
    Got the manual and did some tests.
    The sender seems to be bad.
    Ordered a new one.
