The old carbs are probably usable, but have much internal corrosion, like they were full of salt water at some point.Very nasty looking. I will remove the carb assembly and examine the #2 carb. I will soak it overnight in the carb cleaner kit. I have had great results with it in the past. I should have taken 99Yam40's advice and checked them all before I installed them. A case of logic being over ridden by wishful thinking.
As far as the cam lobes, I have examined them in the past and saw no issues. I think I would rather cut my hand off than remove that cover again! I have only had it off at least 4 times... maybe 5! I have lost count.
