I have a 2011 Yamaha 115XA ,how do you eliminate the water pressure hose from the motor, new to me motor and my boat doesn’t have a water pressure gauge.
Water pressure hose
I suspect that you have a four stroke F115XA. Yamaha stopped selling two strokes several years before 2011.
Normally the hose is not eliminated. It is usually plugged and then left loose within the engine pan if it not going to be used.. The next owner may want to use it. I am surprised that it does not already have a plug in it.
Oops. My mistake. Poor reading skills. I was thinking of the lower unit water pressure hose.
In either case there is not a lot of pressure. Plug the hose or as fairdeal notes, remove the fitting from the block and install the over price Yamaha plug. Or an oil pan drain plug.
Originally posted by boscoe99 View PostOops. My mistake. Poor reading skills. I was thinking of the lower unit water pressure hose.
Originally posted by boscoe99 View PostDo you have data to indicate what pitot tube pressure an F115 powered boat running at wide open throttle can produce?
Standard calibration speedometers should react to the following pressures:
5 PSI = 20 MPH
11 PSI = 30 MPH
19 PSI = 40 MPH
30 PSI = 50 MPH.
A standard speedometer using the Mercury/ Mariner speed pickup in the engine foot
will read approximately 10% faster than with a Teleflex pitot mounted to the transom.
Speedometers with the suffix "M" after the Part Number are calibrated for use with in-foot pickups.
5.6 PSI = 20 MPH
12.6 PSI = 30 MPH
22.4 PSI = 40 MPH
35 PSI = 50 MPH.
You would be surprised how much water gets up into that speedometer hose. In my 20'4" boat, it was easily half ways forward (under the deck) to the speedometer.
I plumbed a Schrader valve in the CC and run a small 12 volt air compressor to it after each use. It'll blow out easily 1/2 cup of salt water..
And that's a top speed of approx. 45MPH.Scott
