i observed that while priming my outboard small amount of fuel seeps out of the fuel filter. Is this a sign of a failing fuel filter? It appears to seep out the top of the filter when under pressure from pumping priming bulb.
Fuel filter question Yamaha 90 2 stroke 2008
Originally posted by bridges27 View PostWill the repair then be to install a new fuel filter?
Originally posted by bridges27 View PostThis is the fuel filter directly above and connected to the fuel pump.
If so, as noted, spin the cup (part #8) off and inspect the o-ring seal. Likely that's what's leaking..
If the seal looks good, clean away residual fuel, prime with the bulb and look for exactly where it's leaking from.
.Scott
Check and replace as needed the o-ring....a dab of grease on the o-ring and plastic filter cup threads helps the assembly go very smooth.....as well as the next time you need to unscrew it....
Originally posted by Rossy299 View PostO ring above bowlScott
ÂÂÂÂÂÂÂÂÂÂÂ
