Zippy wants to know....
  • Zippy wants to know....
    Zippy The Pinhead has two 2005 F225 Four Strokes. One is an F225, the other an LF225, both TURD's. So, one prop goes this way and the other prop goes the other way. Not that there's anything wrong with that...
    Q. Are the water pump kits identical?
    Q. Do both pumps rotate in the exact same manner as I suspect?
    There are a jillion kits...is this the one? 61A-W0078-A3-00?
    https://www.boats.net/product/yamaha...b3c684c95d72f6
    It's time.
    the motors (power head) and drive shafts all turn in the same direction on all motor I have ever seen,
    gear box makes prop shaft and prop turn different.
    so pumps should be the same
    have you looked up the parts to see?
      That was my understanding and assumption as well. I am looking at parts and there are a metric ST of different kits, so I just wondered if maybe things were different. The part no and link I posted is what I believe that I need, minus three washers and a nylon retainer.
