I have a 2004 Z150TXR the motor has never given me any problems until now. It has 1950 hours and has been maintained regularly. This past weekend it was running fine. I was running at 4500 rpm and throttled back to make a turn. When I powered back up I could only get to 3500 rpm. No indicator or alarms. Oil level in bulk tank is good, oil in onboard engine is good, oil pump is working when
i used switch to fill engine tank. Since this issue, I have replaced fuel/water seperator filter, VST screen (VST was spotless), fuel filter in water seperator on engine, All filters were very clean. I also replaced spark plugs. No change. The motor will not idle and runs very rough when it does start. I can run it in neutral at higher rpm's. I am at witts end. Should I buy the YDS software? I am somewhat savvy about computers and have good mechanical skills, but I understand these engines have many safety features on them. PLEASE HELP!! Also, my batteries read low but motor starts and shows charging at 13.7V
