One of our F20LEHA motors came back with the drive shaft sheared off on the motor end right where it tapers down to the narrowest part. Is there any tricks to getting the stub out of the motor. Tried a weak magnet and it didn't work. Thanks
f20 sheared drive shaft removal
You might try rotating by hand (ignition off) the flywheel back and forth slightly.
Unless it hasn't been serviced in a long time, grease is probably holding it up there. Gently tapping the shaft up there may allow it to come down(don't get clobbered!).
Your customers are pretty tough on those boats...jeez..
Please post back what worked (or didn't for you)..Last edited by TownsendsFJR1300; 08-16-2014, 01:53 PM.Scott
No idea...
Depending on the size opening you have way there, can you get a larger magnet, attach to a rod and try that?
I'm also wondering if spraying some lube up there, then gently tapping upwards at the broken part of the shaft may loosen it.
If its been somewhat maintained, it should just be grease holding it up there. If not, may be rust...Scott
I would start the motor and let it run long enough to get good and warm. Maybe expansion of the crankshaft together with vibration will let gravity do its job.
On the other hand, that power plant could be lifted from the mid-section is short order. You would then be able to get a tool on the drive shaft remains.
Originally posted by boscoe99 View PostI would start the motor and let it run long enough to get good and warm. Maybe expansion of the crankshaft together with vibration will let gravity do its job.
The oil pump on the 2006 and newer models per the parts fisch runs off a cam shaft so it shouldn't be an issue with being splined to that shaft..
For the OP, do you know the last time the splines would have been lubed?Last edited by TownsendsFJR1300; 08-17-2014, 03:37 AM.Scott
Originally posted by robert graham View PostWell, better the driveshaft break than the crankshaft or lower unit....wonder what Yamaha gets for a new driveshaft?....
2006 and Later F20LEHA Yamaha Outboard LOWER CASING DRIVE 1 Diagram and PartsScott
ÂÂ
