Hi all.
Firstly I have a 2000 Yamaha 70hp 2 stroke outboard.
It appears that my tilt/trim motor has completely stopped working.
I have tested the relay and all connections and tests good, second test will be the tilt/trim motor. Problem is I cannot access it![Frown](https://www.yamahaoutboardparts.com/core/images/smilies/frown.png)
I turned the manual release screw clockwise to relieve the pressure so that I can tilt the outboard up and down manually by hand. What happened is the outboard went down and now will not go back up no matter how hard I try to lift it. I cannot find any reason why its not free to lift up but it just does not.
So my problem is now I cannot access my tilt/trim motor to try and fix and I cannot get my outboard up so trailering it to an outboard repair shop is out.
Please help, am I missing something?
Any info would be appreciated
Steve
Steve
