I'm looking for the replacement Trim switch in the throttle handle. Motor is C40TLRW. Motor says it's a 1997 model, but appears to be a 1998 as that model isn't even listed in 1997. The numbers on the switch are 10A250V, WI32 and T85. Couldn't find any of these numbers in the parts catalog.
Also, the switch works, but when you push in either direction it stays there. Shouldn't it have a spring return? When you take your thumb off the switch it returns to the neutral position? Or are you suppose to manually put back to the neutral switch position?
