Txrp 1991 200hp tilt and trim seal kit
  • Txrp 1991 200hp tilt and trim seal kit
    My tilt and trim cilynders are leaking around the dust rubber is there a seal kit for the 1991-200hp yamaha txrp ? Thank you makomecrazy
    there are two trim cyl and one tilt cyl. which ones leaking? no there is no kit, each part sold individually
      The long center one and the starboard short one.
        shorts - trim: 2 new seals and caps each, long - tilt: rod assembly, if you lucky, you may unscrew cups without special tool, tons of info here search
          So I found parts for the short ones but the center long one I'm not Shure about the dust seal and o-rings
            The center shaft(tilt), at least on the parts fisch, you have to buy the entire center assembly.
            Another member had the exact same issue and Boscoe99 posted an assembly that the seals alone were able to be purchased that should fit youe T&T unit..
            Here ya go;
            http://www.boats.net/parts/search/Ya...201/parts.html
            I never heard how it worked it, but should work..
            Original thread, Post #9 ;
            http://www.yamahaoutboardparts.com/f...s-th24046.html
