Background: boat started running rougher and rougher, missing until it would not even idle. Decided to clean carbs, replace reeds, check plugs and check for spark. Using a spark tester I had no spark on any coil, using a regular plug I had no spark at any coil, I could find no identifiable power coming from the pulsing and/or charging coil (I must confess, that last one I was just using a test light looking for any power.) I checked at the plugs that plug into the bottom and top of the CDI.
Any type of help would be huge.
Mahalo!
Mahalo!
