After landing my 23' Grady hard in rough seas off a wave the horn came on low (not as loud as in past with a true alarm like low oil).
When measuring to ground the Yellow horn + lead has 12v with ignition on and with engine running it goes up to 14.7 which is normal charge voltage. The Pink to ground has 12v measured with engine running (this isn't good). When measured from the yellow to red feed I get 2.7 volts which is enough to sound the horn at low volume.
Thinking their may be a short in the Pink wire harness somewhere or voltage is getting through the CDI (where this wire comes from). This motor is pre YDS and my winkey is not showing any errors just the warm up and normal run blinks.
Unless I'm chasing the wrong rabbit my next things to check is the Pink wire continuity from the dash to the motor with the wiring harness disconnected for stray voltages, the thermo sensors which also have pink wires to them from the CDI or a bad ignition switch.
Suggestions are welcome.
Thanks for any help
Thanks for any help
