I have a 30hp 2 stroke 3 cylinder Yamaha that's been sitting for several years with old gas in the carbs. Needed to do a carb rebuild on them so ordered the kits and started to dismantle one carb at a time. The first carb, I presoaked in carb cleaner then soaked all the jets and bolts in PB Blaster penetrating oil. The jets proved to be stuck fast and in my attempt to remove them, I mangled them badly. I searched for a tool that would improve my chances on removing the jets on the other carbs. I found at Harbor Freight a micro impact screwdriver that had bits small enough to fit into the recessed holes for the jets. With this impact driver, I was able to fit the slotted head of the jet perfectly and give it a solid hit, applying enough torque to break it free the first hit.
I thought I would post this tool for anyone who might also have this problem in the future.
DSC_0227 by sixscouts, on Flickr
DSC_0226-001 by sixscouts, on Flickr
