I've read several posts on here were it says to ck it just pull your kill sw. and turn the motor over and it should go off. I also read one or two that said this doesn't work with all motors. I tried it and it didn't work on mine or I have a bad horn.
If I just ground the oil pres. sw. shouldn't it go off also or do I need to remove the wire from the sw. and just ground the wire?
Also can the same type test be done on the Water Temp Sensor by connecting the 2 wires to make the horn go off?
This is a 2001 F80LTRY with a 703 control and a single Analog Tach.
Thanks in advance
Thanks in advance
