Sry about my poor English but hope you understand
I Ihave a Yamaha 60hk -95 outboard where ist not possibe to move into forward or reverse.
If I remove the cover of the engine, the mechanism where the wire from the control is fastened is working.
The shift shaft that transfers the rotation from the to of the engine to the gearbox is loose. I can turn it around with my fingers and also move it up/down a bit.
This shift shaft, how is it conetced at the top? Can I access that part in a rather easy way and see what happened?
Unfortunately, looks like the shift shaft is broken, needs to be replaced and how can that be done in an easy way?
