Checked it per manual good reading ran engine loosing rpm and cylinders rechecked while hot pulsar coil readings were bad. Let it sit for few hours readings back. Have anyone seen this? Thanks
Pulsar coil
Certainly some parts can be defective when hot and fine when cold. Or vice versa. They make a product that can be sprayed on hot components so as to cool them down when in use as a troubleshooting aide.
Originally posted by panasonic View PostDo you not have another thread started related to this problem? Going to cause confusion to have two threads going about the same engine at the same time.
I just asked a bunch of questions over on the other thread.
ÂÂÂÂÂÂÂÂÂÂ
