Good evening -
I have a 2000 Yamaha F115EFI that is running on 3 cylinders. Originally had plugged injectors and a contaminated fuel system so I disassembled everything - VST, rail, LP pump, etc and cleaned then flushed the fuel system. Pressure is 40# at the rail, spark is good at all 4.
Getting good fuel spray pattern on all 4 injectors, replaced the spark plugs and still no fire on #4. Can unplug the #4 injector or the plug wire and get no change in the rough idle, all others stall the engine when unplugged. Swapped coils and the problem stays with the #4 cylinder.
Compression is between 190 and 200 on all 4
What am I missing? Should I be looking at a stuck valve or lifter? Hate to jump to that conclusion but this is driving me crazy.
Thanks for any help - looks like a great forum for these motors.
