Fellas in need of help, fuel problems with 250 vmax 4 stroke,
Engine runs then once fuel is burnt from vst it dosent refil, took out the exterior inline pump and hooked direct to battery it turns on but doesnt pump fuel , this all started with a burt fuse by the way, assuming that pump was no good i thought i could try just an ordinary inline pump to see if i could get the vst to fill but hooked it up with no luck.tested the power wires to pump and have 0 v ,should this have 12 v when key is on or only when vst is calling for it . Any input would be great
