Looking for a source to buy the correct NMEA 2000 cables to set up a Lowrance network.
NMEA cables?
many options - eBay, Amazon, Westmarine
long ago Lowrance used some proprietary "Blue" connectors -
but now use standard - so any brand of NMEA 2000 parts will interchange
the Lowrance brand of "starter kit" is one of the better values for what you get
as is their "Yamaha Interface Cable"
Thank you for your response! Very helpful. The plan is to connect the Icom AIS 506 to the Garmin 5200 globalmap chart plotter for the GPS signal and the Yamaha 150TXR outboard to the Chart plotter to read the engine sensors using the NMEA 2000 network. The next step would be to connect the old Furuno 582 sounder to the chart plotter to see actual depths on the chart plotter using NMEA 00183..
Originally posted by Nick on the Bad Habit View PostTemp went as high as 195f at 5200rpm, while doing a shake down cruise. Water temp was 65f.
The outboard temp reading is very different from that of a closed cooling system;
in your automobile temp comes up to 'normal" and then stays exactly there
with your F150 it will 'warm' up to about ~140 at idle/low rpms
but then increase with rpms/load
you'll likely see >200 at high speed, particularly in warmer water
Originally posted by Nick on the Bad Habit View PostThanks for the response! Having the ability to see the operating parameters while under way is a eye opener. Had not idea what was happening before.
An example recently on this forum was guages for the cooling water. We already have an over temperature alarm and a tell tall stream; but the argument was that you could add a pressure guage as well as a temperature guage, and if this was put in the tell tail circuit, there still is confusion as to what these guages will be telling us: ie. is there a blockage or water pump failure or indeed when is there an engine overheat.
It becomes the more information available the more there will be questions and disputes, just like in the "expert" worlds.Last edited by zenoahphobic; 06-16-2019, 07:56 PM.
Originally posted by Nick on the Bad Habit View PostIs there a document that lists the sensors for a 2006 Yamaha 150TXR that can be read by my MFD, with the normal operating parameters?
Well, now that I think about it. No.
NMEA 2000 output was only implemented in 2006 and later four stroke models and two stroke HPDI models.
if the motor is running great, then take some pics of the info at idle and different RPMs
then you have something to look at or compare later on when the motor is not running properly.
or even better write it all down and share with others too
Â
