1988 Yamaha 90 hp triple the two Yamaha LED gauges are toast and in my opinion replacements are too expensive. So I want to replace with conventional gauges by Faria or Teleflex or ? Any suggestions ? Pretty much plug and play or an electrical nightmare ? I'm thinking speedo, tach , fuel ,12 volt and trim at the least. Possibly water pressure. Thoughts ?
replace LED gauges with conventional ? How to ?
It won't be plug and play but it won't be an electrical nightmare either.
Most gauges need at a minimum 12 volt power power and a ground. The tachometer will need a tachometer signal which should be available at the dash.
Get a trim gauge that matches the resistance of a Yamaha sender.
The water pressure gauge won't even need electrical power unless you want it lighted for night time use.
Originally posted by boscoe99 View PostIt won't be plug and play but it won't be an electrical nightmare either.
Â
