water pressure problem ?????
  • water pressure problem ?????
    my yamaha 225 v-max is losing water pressure onleft hand turn and after I staighten out the pressure does not come back up. on right hand turns it'll go down some then come back after you straighten out. The only way to get pressure back up is to motor down and restart take off or slow down and turn motor back and forth and you can feel what seems to be air under boat work out and the pressure comes back. two months ago no problems any suggestions would help. I had a dent in the hull and fixed it so I don't think it's the hull. it acts like the motor should go down? give me something to go on!!!
    How low does it go?
      it goes down to zero according to the gauge
