Hi, My pitot tube is blocked on a tiller-steer 2016 F40. I am aware of the fixes posted on this forum using small hand-held drill bits, compressed air, and irrigation with mild detergent in a syringe. However, I would like to understand the problem by visualising it through a diagram BEFORE I go poking around in with a (hard) drill bit in (soft) alloy. I can see the inlet on the leading edge of the lower leg is a narrow ring of stainless steel (SS) set in the alloy -- but does this SS tube extend all the way up the lower unit to join the rubber messenger tube - or does the pitot tube enter an unshielded gallery cast in the alloy of the lower leg? I have surfed the internet and cannot find a diagram or picture.
(NOTE: I had to buy a whole new lower leg for my first 40hp yamaha outboard (1994 2 stroke, 2nd hand) when corrosion in the pitot tube assembly caused calving of the alloy each side of the lower leg unit. I did not even know pitot tubes existed as nobody I know has a speedo fitted to tiller-steer outboards on "tinnies". Very wary now of flushing pitot tube now, though!!)
Thank You, Mike
Thank You, Mike
