I just had the boat out yesterday and everything was going great but at my last stop before the ramp is shut off when i was idle to spot. I then tried to recrank and the battery was dead. I took to the house and charged and went out this morning and it is really making a clanking grinding noise when the egine is started. I just loaded back up on the trailer. Is it bad news ? Any ideas ?
2003 yamaha vmax, plesae help
thanks ken,
but that noise only happend wants the engine was running. please tell me it is not the worst... i took the cover off and all looked normal. any other ideas ?
penguin,
Check the mounting bolts on the starter - grab the starter and try to move it - it may be loose.
Also, look at the pinion gear with the outboard not running to see that it is down at the bottom of it's travel on the starter shaft - should be about 0.150 clearance from the top of the pinion and the bottom of the flywheel.
Also, look at the pinion gear spring to see if it is broke - you can rotate the pinion gear clockwise and it should travel up the starter shaft - release it, and the spring should push it fast back down the spiral cut on the shaft.
What you are looking for is perhaps the pinion gear jumping up/down on the starter shaft and rubbing against the bottom of the flywheel while the outboard is running.
Ken K
ÂÂÂÂÂÂÂÂ
