I am getting only about 1-2 psig of water pressure (gauge, tubing etc are all ok). I have changed water pump impeller and housing. Pulled heads and head covers to inspect for fouling - all clean. I now suspect that water tube may be cracked/broken or tube seals bad.
How do I remove the water tube that runs up from the pump discharge to the power head? Should it just pull out once the lower unit is removed?
Thanks,
Travis
Thanks,
Travis
