I have a 90 HP Yamaha engine ( 90ETLG ) jet drive. (serial # indicates:1988)
Starts and idles fine, put throttle 3/4, then to full, it takes off normal, good jump..., then 10 to 15 seconds later, it slows down and runs rough, takes about 15 seconds to recover, then idles great again, put into gear again, same 3/4 throttle and then to full throttle, after 10 - 15 seconds, it repeats the slow down and rough running until it recovers again in the same amount of time...
So I take off the cover to the engine, repeat the same procedure, put the throttle to 3/4, then full again.., now it runs without the slow down, no problem, runs smooth with no slow down.
I took it up-river, full throttle for an hour straight without any problem, it ran smooth and strong, then I stop and put the cover on, and same thing as before, put the throttle to full and within 15 seconds , it slows down and runs rough again.
Took it to a local authorized marine shop, they checked out the normal list, took off the carbs, cleaned them, re-set them, checked plugs, wires.
I took it out for a test run, same problem, didn't solve anything.
Looking for a Help...
