A friend has:
115 HP 4 Stroke EFI
Model F115TLRB
Serial Number 68VL101495
After the boat is cruising on plane and brought abruptly to idle, the motor will die.
The motor runs perfectly at idle and all RPM ranges while on plane.
Then it will not start until after a cool down period of at least 15 minutes (time can vary).
He brought in for service. I was with him. He explained the entire scenario.
The dealer replaced both fuel filters, spark plugs, oil.
Of course the motor started after this work was performed.
However, once on the water the same problem persists.
He has discovered that he can start the motor by pushing in the button on the remote control,
raising the engine speed and turning the ignition key.
The engine will die if the engine speed is reduced and the shifter is in neutral in a normal manner.
However, if he very quickly lowers the engine speed and shifts into neutral and into forward the engine will continue running.
What should his next steps be?
What is likely the problem?
115 HP 4 Stroke EFI
Model F115TLRB
