We also drained the vst and hooked up an external gas tank to make it sure none of the symptons are fuel related. No change.
Ox 66 smoking bad
We took another look at the oil pump o ring and decided to change the o ring since it was $10 part. The yamaha service tech suggested fuel pumps first and then suggested a whole new oil pump after I told him the pumps were brand new. Are these known to go bad? I have heard of the linkage rod breaking but not the pump. Looking for feedback before I drop more money on another part.
It has been hard for me to find time to finish this repair, but had a chance to swap out the oil pumps last weekend. It was the seal on the pump shaft that was causing the issue. I had previously replaced the o-ring that goes between the cranckcase and the oil pump, but it turned out to be the pump itself. It was evident when I took the pump off the block and there was a bunch of oil coming out of the cranckcase. After replacing the oil pump, the smoke is now a normal amount and burning approximately 60:1 on a trip with a bunch of idling.
