Hey guys how's it going. I've got a 1994 Yamaha pro 60 and ever since I've had it I've had to manual choke it it starts up great when I use a manual choke but will not start at all without it it doesn't seem like the electric choke is engaging whatsoever any advice on where to go from here.
94 pro 60 choke problem
So with the cowling removed, you turn on the key, push the key in, and nothing happens? You do not see / hear the solenoid actuating to choke the cold engine?
Does the warm engine start without the choke?
How long have you owned this engine?If its got teats or tires, you bound to have trouble with it....
well since Boscoe says it does not have a choke I am deleting this post I made.
heck I cannot even find the way to delete it except erasing the words I typed.Last edited by 99yam40; 05-17-2019, 05:50 PM.
How are you manually choking the motor?
A 1994 P60 does not use a manual choke. It uses an automatic fuel enrichment system known as PrimeStart.
Are you turning the PrimeStart red lever to the ON position in order to get it started?
well I would think that your carbs are plugging up, and not letting enough fuel thru .
time to take them apart and see if you can clean all the passages up including the prime start systemsLast edited by 99yam40; 05-17-2019, 11:22 PM.
Originally posted by Ncpoteet1 View PostI think you might be right. Any good videos on doing this
Originally posted by 99yam40 View Postwell I would think that your carbs are plugging up, and not letting enough fuel thru .
If the engine runs fine manually activating the Prime start, the carbs should be fine.
I'd be pulling the prime start unit and checking that and the wiring (for power) to it..
And plus 1, Danger also has some video's checking that unit.
Originally posted by Ncpoteet1 View PostI flip the lever up and once it's started I put it back to level or norm
it was my understanding that the normal position was full counter clockwise.
I may be wrong, but check to make sure you are not leaving it in the off position once the motor is started
Head over to YouTube and check out Dangar Marine. He has a large series of videos on all manner of topics. At least one on Prime Start. Plenty on carb cleaning in general.
Originally posted by Ncpoteet1 View PostI'm using the prime start lever in inside the motor to start. My key does not push in like other key panels do.
So you have to remove the cowling, flip turn actuate the primer, get it started, and then reinstall the cowling... yes, that is unacceptable. What a PITA that must be.
I suspect, if you think I am on the right line of thinking, that we should be able to help you either test/fix the system or guide you to install a more convenient remote button of sorts.
I was really hoping that you didn't realize that pushing the key in was how to remote prime/choke the engine. I had been boating for three or four years before I figured it out or someone showed me the "push key to choke". Well, It would be another 5 years until I was old enough to get a drivers license and I had a whole bunch more stuff to learn then...Last edited by FabricGATOR; 05-18-2019, 12:12 PM.If its got teats or tires, you bound to have trouble with it....
if it prime start heater was just not connected electrically, then it would fire up fine cold, but would run too rich after warm up.
I still want to know if it is really in the normal position when not starting
ÂÂÂÂÂÂ
