The hour meter runs only when a tach signal is received.
The tach signal comes from the ECM,
through the green wire of the main 10-pin cable,
then to the tach.
You should check the connection and wire integrity
starting with the green wire coming out of the tach
(the individual green wire that ends in a bullet plug)
and follow it
to where it is connected to a green wire coming off the keyswitch.
If that checks out OK,
separate the connector black plug at the keyswitch
and inspect the pins & sockets
then separate the black plug at the engine,
inspect those pins & sockets.
Or you can start by confirming continuity
from the engine plug, to the green wire at the tach
here is the pinout for the engine/harness plug:
You can test for the signal itself,
when the motor is running,
if you have a meter that measures Hz
it is an AC current, whose frequncy is proportional to rpm
then to the tach.
and follow it
