I have an Alumacraft MV1860 with a Yamaha F90. I recently changed out the factory aluminum 3 blade prop (13 in X 19 pitch) which would run WOT at 6100 RPM which is slightly above the recommended range. I replaced it with a Solas stainless steel 3 blade prop (13 in X 19 pitch) which now runs WOT at 5400 RPM. I did pick up about 2 MPH on the top end speed.
My question is related to the WOT RPM of the new prop. It's right in the middle of the recommended range, but I was hoping it would be closer to the upper end. Do I gain anything by repropping to get another 400 or so RPM or is this good enough?
