Hi
I recently purchased a little used Yamaha F50AET outboard from 2001. When I twist the key the first notch, I expected oil pressure and temperature lights to light up, and then to turn off when the engine is running.
My lights are completely dead...
I have checked bulps by testing the wires that go out of the motor, by putting it to ground (both the green wires, with the ignition on the first notch, without the engine running), and then the lights are working. I think everything is in order from the plug in the engine compartment to the warning lights in the tachometer.
I have short-circuited the temp sensor without light lit up or beeping in the control box, tryed to putting the oil pressure switch to ground, including taking off the cord completely, but no light / sound then either.
Both wires from these sensors enter the cdi box....
Is there someone who has experienced similar problems? Seems to me as if the cdi box is the problem.. -the warning lights do not light up BEFORE the engine is started, nor if they are bypassed as if the engine was too hot or have too little oil pressure ..
Motor is running fine and no other problems ..
Mrs. Ole Marius Petterson
