New to me 1988 90 hp on a Hydra Sport hull. When I purchased the rig two weeks ago I had the seller demonstrate that the trim/tilt worked and it did. When at home a few days later the trim worked but the tilt did not. Electric motor sounded fine. I manually raised the motor and pulled the fill plug and put in aprox. half a tube of trim/tilt oil. Put the fill plug back in and she works fine. Nice and smooth through up/down rotation with no sounds of struggling. However the tilt lacks about a 1/4 " of lift to allow the manual locks to swing down
I can see that the tilt cylinder does have a small leak when in the " up " position so I know why it needed some fluid. In the fall I will have that fixed but do you think the worn seals are the reason it won't lift quite high enough ? I think short term I'll purchase one of those outboard stern saver or whatever it's called to hold the outboard in a somewhat upright position for trailering.
