Anybody can answer this.
2005 F225TXRD
Bought one to rebuild a bit ago. Measuring out the cylinder bores, I think I have 1 cylinder that needs to be bored out a bit.
Reading through the service manual it says that if a cylinder is out of spec to rebore that cylinder.
2 questions here.
1). The way it is written it indicates it is singular...as in only rebore that one specific cylinder. Is it acceptable to rebore just one cylinder oversize and run STD piston/bores in the other cylinders? I've always bored all my cylinders out the same size.
2). It appears that yamaha does not even sell oversized pistons/rings. Why would they tell you to bore it out (opposed to sleeving) if they don't even sell the part for it?
Extra question: Where do you buy your oversized pistons/rings from?
2005 F225TXRD
2 questions here.
