Hello,
we bougt a Yamaha F50 H 2 Weeks ago. Now we wired everything up and got to the Point with the Y-Cop System. The Engine is allready running but i only see a " - " in the display so no RPM Signal. The Transmitter i think is also not registered propper because in the manual it says turn the ignition key to off and press unlock. So i did. it should beep , and it did. After that it says turn on the Ignition and it should beep again witch it does not.... Can anyone help me with this Problem ?
Thank you very much.
Many greetings from Germany !
Thomas
Thomas
