Originally posted by fairdeal
View Post
The ECM is wired into the primary ignition circuit. You can usually see that on your wiring diagram. The black/red and black/white wires. The ECM receives a signal from the pulser coil, then it interrupts the primary circuit. This in turn, collapses magnetic field and produces the spark in the secondary circuit. In TCI, the battery is directly responsible for creating that magnetic field. But the ECM determines when that magnetic field collapses. If the ECM or the pulser coil is not doing its job, the output peak voltage in the primary circuit will be lower than the manual spec.
