I switched out the TPS on my 2005 f225txrd motor rund well 650-685 rpms, only issue I am seeing in the YDS is a negative throttle angle of -2.9, specs call for -1 on up,would making a small adjustment on the TPS help this out? voltage on TPS is .605. thanks
Replaced tps
looks like you are talking about 2 different things TPS and ISC
hopefully someone with the proper knowledge will be along shortly to help you
I actualy had 2 issues, tps was in need minor adjustment to bring up to spec, was .605mv,small move and now at .700mv anf throttle is 0-1.thanks for help
Originally posted by scottod17 View PostI actualy had 2 issues, tps was in need minor adjustment to bring up to spec, was .605mv,small move and now at .700mv anf throttle is 0-1.thanks for help
ÂÂÂÂÂÂÂÂ
