yamaha703 70hp outboard
  • yamaha703 70hp outboard
    where do I find the drain plug on the Yamaha 703 70hp outboard thanks
    can you tell us what exactly is a Yamaha 703 70hp outboard?
      Yes, and what it is that is to be drained.
        Model #and year would help too..
          Yamaha outboard 70 hp
          Hi the engine is from the 90s it's for the oil in outboard need to check it thanks dave
            All I could find for the 1990's, 70hp are TWO STROKE engines. There's oil in the auto lube tank, in the lower unit. ???
            Is it a four or two stroke, should be a model # on a plate on the side of the transome bracket.
            If not snap a pic and post it...
              yamaha 70hp
              thanks scott will do
                yamaha 70hp
                hi scott
                i think its 4 stroke i have found one plug on side of bottom of engine
                the number i got was 70 BET 6H3 L 350545
                  According to my book, that serial number range equates to a 1985 model.
                  John
                    If it has a dip stick in the crankcase, usually yellow, and oil reqisters on the Hash marks on the stick, (Like your car), its a 4 stroke.
                    If it has a rubber looking drive belt running inbetween the crankshaft and two larger pulleys, its a 4 stroke.
                    The drain plug for the engine oil is usually recessed into a rubber tube, toward the rear of the engine. The tube would be angled outward and large enough to reach a socket in there (probably a 14mm).
                    For the 1985 models, I could only find a 2 stroke in the above fisch look up.
                    A picture uploaded from your computer would make things much easier....(Under the cowl hood)
                    Where/ what country are you located in?
                      A 6H3 prefix Yamaha is a 70 two stroke.
                      Carburetor drain plug?
                      Lower unit drain plug?
                      Oil tank drain plug?
                      703 is one model of a control box.
                        Well the two stroke part helps, tks...
                        Guess its 20 questions time!!
                        David, if you could answer the above questions, you could get your answer...
                          yamaha 70 hp
                          hi
                          thanks for all the information there is a black tube hanging I wondered what that was for I thought it had come unattached it must be for the drainage
                          I will try and get a picture put up
                          many thanks again dave
                            Good luck what ever your doing....
