Interesting thing happened yesterday. A neighbor whom I have never met, saw I was working on my year 2000 ox-66 sx/lx 150's (lowers and a T/T unit) and offered a pair of 2006 200 HPDI's... I think they may be Z-max.
Should I take a look? Supposedly, his son upgraded to a pair 300's
You fine folks' knowledge and experience is greatly appreciated. Pro's / Con's
►Problematic? Weak points? Look at / make sure this is....
I think I read about inherent problems and upgrades to oil pumps or injection systems... Perhaps not the 150/200's ►thoughts?
►Will they perform well on an offshore (Atlantic) Florida fishing CC? Usually if we fish offshore, we *****? (This is now a trailer boat, not moored for any great duration)
*not sure if this is still going to be censored again. the little Norwegian or Danish leprechaun under a bridge (silly puritans) can't type T R O L L
►*Will my four, new replacement Yamaha LCD gauges be compatible? Perhaps better options...
►Is the fuel savings worth the effort. (currently, WOT is close to 34 gph, of course, not run like that,much
►Do they use the same remote oil tank system?
IIRC, I thought someone once said (perhaps here) that the run of the mill HPDI's and the Z-max HPDI's are a little different and the Z-max is more for the high speed bass boaters blasting off towards a spot... Is this close to real thinking and if so, do I not really want Z-max?
Thank you folks for your comments. I (we) always appreciate you experience and guidance.
Cheers!
![Smile](https://www.yamahaoutboardparts.com/core/images/smilies/smile.png)
Cheers!
