I am replacing the gear pump assembly on my VX150TLRZ trim and tilt unit. I didn't get a chance to see how a couple of parts were positioned in unit. During disassembly the parts fell out.
look at number #27 (pin Part number 64E-4381G-00-00) and number #28 (ball Part number 6E5-43858-00-00).
***LINK TO BOATS.NET ILLUSTRATION IN QUESTION:
2001 VX150TLRZ Yamaha Outboard POWER TRIM TILT ASSY 1 Diagram and Parts
I need to know if the pin #27 inserts into valve seat #29 and the ball #28 is inserted on the outside of the valve with pin?
***OR***
Does the ball #28 go inside the valve seat #29 and then the pin #27 holds the ball inside the valve seat?
Also...does the valve seat insert into the main unit housing with the pin towards the main housing or towards the gear pump?
***OR***
