Does someone know the measurement from tip to base on a Prime start fuel enrichment valve when fully retracted? My measurement is 1.07’ and I feel it should go further in.
In SM there is a way to test that the valve extends, and it does, but I think it doesn’t retract enough to let fuel by when cold.
I have cold starting problems when in normal mode. Engine starts a lot better when lever is in emergency mode. Engine idles good when up to temp.
Ignition is tested good on all cylinders with spark gap tester, 9mm gap.
Motor 2002 90TLRA 2-stroke.
