recently acquired a 1988 Pursuit with 2, 200 2 stroke Yamaha. I am having issues with the oil transfer on one of the motors. I have a couple of questions that I could use help with.
1 I need to get a good repair manual and a operator's manual. Not sure I under stand the lights and indications adequately ( based on some of the info on this forum). Don't understand all the lights on the instruments. Suggestions on which manuals?
2 Initially thought the oil transfer issue was the strainer, took out and cleaned. no change. jumper the transfer motor to the battery- oil was pumped to the tank on the engine. Thought that meant the oil gauge assemble was bad. Not to sure now ( again based on what I have read here). Thoughts ?? Plan to use a jumper to by pass the switch in the engine tank to test my assumption.
3. Not sure of the model number. The label on the engine has been painted over. Anyway other to tell. Thks for help in advance ed
