You're going too fast... back up and keep it simple. Did you run the engine and try the simple tests as listed above? You may be chasing your tail with these diagrams for nothing - it may already be hooked up properly. If the tests are negative, then let's figure it out - but for now, it might all be for not.
1997 Yamaha 225 Saltwater II Battery question
the layout seems a bit odd to me, also - I modified a Blue Sea diagram.
But simply for getting the engine current to the house battery,
it doesn't matter at all whether you connect the Aux lead direct to the battery,
to the battery side of the switch, or the 'load' side of the switch.
Yam must be working at the farm.
Since I have never owned or wired up a rig with a battery switch, I have stayed out of this.
But common sense would say that the battery switch should be able to be turned off so nothing could drain the batteries.
Should or could the Yamaha motor depend on the diodes in the Aux lead to keep that from happening, I do not know.
I plan on heading to the farm to work on fence tomorrow tho
Originally posted by 99yam40 View PostSince I have never owned or wired up a rig with a battery switch, I have stayed out of this.
Originally posted by dmwascher View PostMy Model number is S225TXRV and I have uploaded the diagram from my book. I will be looking today and see if I can find the port or the red wire that everyone says I should have and get back to everyone.
Thanks to everyone that is commenting
. 20190327_224325.jpg2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
AUX connector.jpg Do you have a round milk white connector with a seal cap on the STBD side of the cowling? I believe that is the connection for the AUX charging circuit if I remember correctly. Mine is a year 2000 ox66 150.
Someone proposed that the two red wires on this both go to the positive of the recipient battery (that Yamaha chose to use two lighter wires as opposed to a single heavier gauge wire) Can anyone confirm this?If its got teats or tires, you bound to have trouble with it....
I remember trying to source the other end of that connector to make a harness that I believe is NLA.
Actually, I believe that this installed [seal plug] can be used as the connector if only we could find the correct contact pins.... I forget if we require male or female pins to fabricate this.
PS: I buy Yamaha type connectors and terminal pins from an Canadian living in Japan through a motorcycle enthusiast Eastern Beaver
https://easternbeaver.com/Last edited by FabricGATOR; 04-01-2019, 11:47 AM.If its got teats or tires, you bound to have trouble with it....
Folks, don't forget the rule of Yamaha. If there is one way or one part to get something done then why not use many ways or many parts?
It appears that the battery cables (aka wire harness) for the OP's model seem to have the isolator lead built in.
Has the OP checked out?
